Sponsored by: Kumho
Remove rear spring spacer?
Old Nov 11, 2003 | 05:10 PM
mleichtle's Avatar
mleichtle
Hi Guys, I have an '82 F150 4wd reg. cab short box. Old plow in front. the guy I bought it from says it has 1 ton springs on it. can that be true if the front springs are coils? Also can I just take out the spacers under the rear springs and just bolt the spring right to the axle to level it? or am I gonna mess up the drive shaft? I know I'm going the wrong way but it still sits kinda high.
Old Nov 11, 2003 | 05:40 PM
racsan's Avatar
racsan
i removed the lift blocks from my '93 4x4 ranger because i thought the back end was way too high. now sits level. no problems. i still have the stock shocks need to put on 2wd shocks. the only thing i would worry about is the driveshaft bottoming out if you hit a really hard bump. that could knock out u-joints or damage the transfer case. i need to remove my driveshaft and see how much compression travel i have left. i like the "level" look better. hard to get the spare out from under now.
bass-n-fire
1997 - 2003 F150
Dec 24, 2016 11:59 AM
TitanoBlu
May 26, 2016 10:00 AM
1972RubberDuck
May 11, 2016 02:25 AM
4x4 94 f150 302
Offroad & 4x4
62
Jan 30, 2008 11:03 PM
Desert Dog
Bronco II
16
Dec 15, 2006 09:39 AM
