I have had the PSOM rebuilt, just to cut that out of the equation, but same symptom. Random PSOM power failure.
Today, I have it all apart again and am checking for shorts and so forth. So far no dice.
The only thing that is on that same fuse 18, circuit 296 that I have touched recently is the shift interlock solenoid. When I removed an aftermarket alarm system last year I found the solenoid was unplugged. I plugged it in, and it seemed to function normally. If it was shorting to ground shouldn't it blow the fuse? Ditto for a short to ground from a chafed wire? I have looked over my work from removing the alarm system and so far I haven't seen any other connection with the PSOM.
The last time it happened I still didn't have the presence of mind to take note of any other dead systems... So far no luck in replicating the problem in the driveway.
So far I have been focused on the power side. I guess I need to check the ground circuit as well.
I had a PSOM rebuilt not that long ago and the problem wasn't fixed with it. The rebuilder took another look and claimed that the PSOMs glitch was likely in one of the chips, which are not replaced during a rebuild.
A rebuild is basically replacing two capacitors.
A known good PSOM is the only way I discovered that the rebuilt PSOM, which tested okay on a bench test for 1/2 hour, was still bad.
Originally Posted by R&RFord
So, this problem persists.
Yes. The wire not being secure in the fuse block was the main problem.
The wire was stiff enough that fuse was not pushing it out of housing completely, but was only making an intermittent contact. With the fuse removed it pushed back into the housing and visually looked like all the other connectors. Only caught it when it moved when checking with the meter.
I just went through this EXACT problem on my 1993 and it turned out to be the Fuel Heater Wires that went to the Fuel filter. it had been deleted and the wires never correctly taken care of and they were grounding out. that circuit shares the fuse with Fuse U? IIRC. The very same fuse that also provides power to the Electronic transmission control and the PCM power relay coil. it killed power to the TCM/PCM and killed the speedo/Tach and sent the transmission into limp mode.
Glad you figured the issue out! if it comes back i'd highly recommend checking those wires as well.
