2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Air dam
Old Sep 16, 2022 | 07:53 PM
Rancheroracer's Avatar
Rancheroracer
Air dam
Ok, I'll bet one of you can help me. How can I manually active the front air dam on my '21? Jumper wire or toggle switch if that works. I assume it uses a relay, could I tie into that? I run truck in 4H at the drags and the air dam doesn't deploy in 4H. Tire spin in 2 whl.
Old Sep 17, 2022 | 09:59 PM
Binkowski's Avatar
Binkowski
I wonder if that's something you could set with Forscan? I imagine there's a setting in the programming for when and why it deploys. Perhaps you could change the programming to have engaging 4H to deploy the air dam. Just a crazy thought. Of course, tying in to the relay would be easier.
Old Sep 18, 2022 | 01:18 AM
Rancheroracer
Thanks for the post. I'm not up on Forscan, need to check on that. I need to research where the relay is.
Matt5
Mar 9, 2011 03:23 PM
350steve
New Jersey Chapter
Aug 14, 2007 05:37 PM
