Sponsored by: Real Truck
Loud quick rumble front left wheel on freeway
Old Sep 13, 2022 | 08:51 PM
bajaphile's Avatar
bajaphile
2001 F-350 V10 4x4 Crew Cab Short Bed 4R100
Driving on the freeway this morning at about 70mph, going straight and on flat ground, a very loud/startling rumble noise came from the front left area of my truck. At first I thought the ABS system had kicked on. The sound was very similar to what it sounds like if your tire rubs the plastic fender. It lasted 1-2 seconds and then nothing else. Drove an additional 40 miles on freeway and it didn't happen again.
A few weeks back my ABS light had turned on for no apparent reason. ForScan showed a C1222 (Wheel speed mismatch code) then turned off within a few mins. My front left wheel bearing/ABS assembly is original... Not sure if they are related... I verified my hubs were unlocked, nothing else is turning up front.... Assuming it might be an early failure of wheel bearing? Anyone else experience this?
Old Sep 13, 2022 | 11:37 PM
leadmic's Avatar
leadmic
Replace your unit bearings their bad.
Old Sep 14, 2022 | 07:40 AM
Djosbun's Avatar
Djosbun
Wheel bearing is bad.
— Dave
Old Sep 14, 2022 | 08:45 AM
WWR's Avatar
WWR
Vacuum hubs?
Old Sep 14, 2022 | 09:42 AM
bajaphile's Avatar
bajaphile
Thanks guys.
Yes, I have the vacuum hubs, but no vacuum lines going to them
Old Sep 14, 2022 | 10:13 AM
acdii's Avatar
acdii
Get a jack under and spin the wheel, if the bearing is going you should feel or hear it. If it was only a couple seconds, maybe you picked up something in the road that you didn't see, that the tire rubbed against and then fell away. Usually when a bearing is going, they gradually get louder, but don't suddenly make a lot of noise and then go away, when they do make a lot of noise suddenly, they either keep making noise, or fall off. I had a bearing on my 2012 that was bad. Didn't make a sound, and spinning with the wheel on felt smooth. It wasn't until I had the front end apart replacing ball joints and such that I notice the bearing going bad. It had a roughness to it when turning, and that was off the vehicle that I felt it, the spindle absorbed whatever roughness was happening as it felt smooth when in the spindle. On the 99 DRW I had, the hubs didn't make noise, but when on the jacks, I could definitely feel roughness to them, they were pretty bad when I replaced them, they were grinding when spun, but didn't make any noise that I could hear while driving.
Old Sep 14, 2022 | 01:57 PM
Pickupmanx2's Avatar
Pickupmanx2
From my experience with my '15 Ram 3500, ABS light came on, road was rough so I attributed the noise to road surface... light went out, 2 days later the RF wheel bearing gave out... I would take it as an early warning and rplc both front units.
7.3 Powerstroke Guy
Dec 13, 2018 12:31 PM
jbwilli
May 16, 2011 09:47 AM
mzerio
Aug 14, 2009 01:19 PM
xjcamaro89
2004 - 2008 F150
27
May 16, 2009 10:29 PM
mcanik
1997 - 2003 F150
Mar 4, 2008 02:01 PM
