overheating issue
Old Sep 14, 2022 | 12:49 PM
AuroraGirl's Avatar
AuroraGirl
Originally Posted by CurtDaMerc
This truck is rather new to me. But I suspect the previous owner did away with the smog pump and just installed a shorter belt? There is no fan shroud, as far as the water pump I will have to crawl under and see if I can find a part number when I get home cause I cannot figure out where the part was bought from and so I can’t get part numbers from the store. The pcv hooks into the side of the air box the tv cable seems to be functional as far as I can tell. If you haven’t picked this up yet I’m not much of a mechanic myself so apologies for trying to fish answers out of a monkey
there is a bypass pulley you will need and your shroud need may be fillable by yard or ebay
Old Sep 14, 2022 | 01:50 PM
toolman60's Avatar
toolman60
LMC truck should have a shroud
Old Sep 14, 2022 | 09:20 PM
Prototypemech's Avatar
Prototypemech
Codes are still retrievable with a burnt out CEL. You'll just need a test-light and connect it to the diagnostic port. Lots of articles about how to do that.
Old Sep 17, 2022 | 09:05 PM
CurtDaMerc's Avatar
CurtDaMerc
4wd Low
Well guys I think I’ve found my problem. After a lot of reading and testing I found the timing was retarded almost 10 degrees. I’m not sure if the distributor slipped or what anyways I set the timing correctly today and I have had an issue with overheating yet. It might be a little early for celebration but I’ll keep an eye on things and be sure to let you guys know if it’s actually cleared up.
Geoooffreyyy
Jun 29, 2021 11:48 AM
Ethobling
General Automotive Discussion
Jul 5, 2020 04:52 PM
thedopefishlives
Jul 10, 2018 02:08 PM
aurgathor
Aug 2, 2006 11:26 PM
randy63
1978 - 1996 Big Bronco
19
Jul 6, 2003 05:50 PM
