1966 - 1977 Early Broncos
Skates
Old Sep 11, 2022 | 06:34 PM
Bobtailfan's Avatar
Bobtailfan
Skates
Hello team,
I am looking to move my 1970 bronco into my freshly built polebarn to begin working on it. I would like to be able to move the bronco around and out of the way when I am not working on it. Has anybody purchased a set of skates for moving your bronco around? If so, please offer some good choices and ones to avoid purchasing.
Thank you,
John
Old Sep 11, 2022 | 08:07 PM
Beechkid's Avatar
Beechkid
This is one of those good news/bad news replies.......
Go-Jack makes the Best skates IMHO, but they are excessively expensive. What I did was years ago I purchased 1 pair because I was in immediate need, but then I mad my own and used caster wheels that were rated at 225 lbs each and had roller bearings inside..... that is the criteria (IMHO) to having a good set of skates and why the "cheap" ones are worthless (no bearings)
RWM Casters UPB-0312-06 3" x 1-1/4" Urethane on Polypropylene Wheel with Ball Bearing for 3/8" Axle, 225 Pound Capacity: Amazon.com: Industrial & Scientific RWM Casters UPB-0312-06 3" x 1-1/4" Urethane on Polypropylene Wheel with Ball Bearing for 3/8" Axle, 225 Pound Capacity: Amazon.com: Industrial & Scientific
Old Sep 12, 2022 | 11:49 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Tires still on it? What size, width wise? I recently got a 4 set of these below. Heavy Duty, very solid made. 80 lb box, USP guy hated me for a week. I have 35x14.50x15's and they cover the skate but still works perfect. You can set Bronco on them with tires or with just the drums...you still need a jack to lift to install. And only good for use concrete floor, NO outside in the gravel, obviously.
https://www.northerntool.com/shop/to...0521_200430521
With this style NO jack needed, but needs to have tires on it. https://www.northerntool.com/shop/to...2550_200612550
And if you are at Northern Tool look at this. https://www.northerntool.com/shop/to...0071_200940071
Or Cat off road jack. https://www.northerntool.com/shop/to...36429_20093642
Or same jack as above just more $.
Amazon Amazon
Avoid cheap, or cheapest on Amazon or Harbor Freight skates (car dolly).
“The bitterness of poor quality lingers long after the sweetness of low price is forgotten.”
BIGKEN
2021+ Bronco
Sep 2, 2020 08:57 AM
SDElwood
Jul 4, 2015 12:43 PM
SDElwood
1978 - 1996 Big Bronco
Mar 31, 2015 07:15 PM
Ryan87lx
Oct 28, 2006 01:52 PM
