need help identifying connector
Old Sep 10, 2022 | 12:17 PM
sterbyn's Avatar
sterbyn
5th Gear
Greetings!
I have a 2002 E450 v10 Superduty on a class C motorhome. We've had some mice issues, chewing through several lines. I've fixed most of them (I am by no means a mechanic but I can splice a wire easy enough), but for the life of me I can't figure out what these are below in order to find a replacement. My engine light is on and the code says P0443 so I figured it has something with the EVAP system, but searching for wires associated with that didn't help either. The male half of the adapter (undamaged) looks like it has a fuse attached to it, which I may need to also replace as I drove this from the lot to my home to work on it and briefly smelled a burnt electronics smell (I got smart after getting home and unplugged the adapter completely, didn't smell anything after).
Anyway, any help would be appreciated!
You can see where the wire got chewed through
This is the male adapter it plugs into
This is the adapter on the chewed part of the line that I am looking to identify and replace!
Old Sep 11, 2022 | 05:11 AM
JWA's Avatar
JWA
In the Van's Tech Folder there is a link to the Motorcraft pigtail connector catalog. Because its provided in a PDF document I cannot successfully link it to this post. From the link in the Tech Folder you can view and download the catalog.
If you had an EVTM the still visible or available wire colors could help identify the circuits to which those connectors are associated.
Old Sep 11, 2022 | 07:23 AM
manicmechanic007's Avatar
manicmechanic007
That connector is for the BOO switch you would have if you had cruise control
Old Sep 11, 2022 | 06:13 PM
sterbyn's Avatar
sterbyn
5th Gear
Thank you both for the information! I should have checked the tech folder first, that connector PDF is great!
sterbyn
Sep 11, 2022 06:12 PM
Krikle
Electrical Systems/Wiring
May 14, 2022 05:20 PM
TexasTrucks
2004 - 2008 F150
Feb 27, 2022 03:38 PM
bigcanoe
2004 - 2008 F150
Feb 6, 2022 03:51 PM
redneck1991
Jun 1, 2015 09:34 AM
