Are the shoes set up to the drums? if they wont lock at high setting have the mechanic check the adjustment (intial set up). if that is off then the self adjusters will either not adj or take forever to bring them up
I Talk to Mechanic this morning, he said "yes of course" also rechecked after test run. I'm thinking trucks not sending enough or inconsistent voltage to the brakes on camper.
Or maybe brake wire is pinched/rubbed/corroded under camper. I guess I can pull the under belly loose and check the wire the whole length.
Also been thinking about buying old school, hang under dash brake control and see what happens.
Originally Posted by Mx113
I’m surprised at all of these high settings. I have a 30 ft gooseneck, that weighs 23,000 pounds loaded with hay, and I set the brakes 3.5 heavy electric. Anything more than that gets really grabby. The 40 ft trailer, which weighs 30,000 loaded, runs at 4.0 heavy electric over hydraulic.
I agree. Ford completely over engineered the built in brake control and plug, or at least the truck computer side of it.
OP, you wrote the drums were not replaced. Were they resurfaced? Did your mechanic verify the drums roundness is true?
I had a similar situation as yours with my dump trailer. Bearing Buddy leaked and the shoes were contaminated with grease. Replaced all the necessary parts but not the drums. I was told the drums were not perfect and the shoes might take some time to seat. I could have new drums installed but decided to try it out. At first, braking was inadequate even at high controller settings. Over time, the brakes got better.
I think the variation in brake controller level others have reported is more due to variability in the brake performance (e.g. drum vs. disc) and not the controller.
I forgot on the higher end trucks, I do have settings for the brake controller on the driver screen, something like low, medium or heavy and and if it's electric over hydraulic.
The Ford brake controller has settings based on what you choose here. So 9 on low is not the same as 9 on medium or 9 on heavy. I started my 7k car hauler on low and could never get lock up. Switched to medium and can't go above a 4. So op check how your trailer is setup. I don't know what Ford recommends as far as this goes with trailer weight. I assume it's on the manual where the break is between the 3 settings
He said drums not scored/grooved or cracks. Did not mention roundness. But I've never felt any brake pulsating but may be hard to feel from way back there. I will check in to drums.
Also was wonder about new shoes seated in. Only 100 miles on with new brakes. Trailers 2021 Montane with about 10k/12k miles on it mostly highway. Michigan to California a few times.
We got camper new.
Correct... have tried multiple / all setting in trailer tow screen on dash. only difference lower #'s = even less braking. Everything set at max. at the moment
Acquired a new car hauler this summer. Brakes were worthless even at high gain of 9 on the integrated controller. Checked the mfgr manual thinking I would need to adjust the brakes manually perhaps. I was surprised to see mfgr instructions to "cure" the brake pads and drums by repeatedly applying trailer brakes from 40mph until 20 mph in rapid succession until the brake drums were indicating some ridiculously high temp using an infrared sensor, then cool and do it again until the brakes "operated in a satisfactory" manner. Didn't bother with the temp sensor, and simply repeated the 40-to-20 process about 15 times, pausing for a few minutes every 5 or so, and now the brakes act as expected at about 2.5 empty and 5.5 loaded.
Went through this today with a new 5th wheel 337rls. Crawled under and adjusted all 4 brakes and 3 of the 4 were so far out of adjustment it was stupid. Took it for a spin and it was significantly better. I just need to cycle them some more and things should settle in. Drove it home 500 miles worried sick someone was going to pull out in front of me. I had a feeling they were not adjusted properly and i proved it this morning. You can’t trust anything these days.
Did you change your trailer brake setting? In the driver information screen under your towing you can change your brake type to electric over hydraulic. I don't see where you said that's been done. I may have missed it.
25 foot AS here as well. My brake controller is set to 5, but will probably drop it down to 4 to make it less aggressive
Yeah, I'm supposing that there may be some variation from truck to truck and trailer to trailer as far as sensitivity is concerned. 2.5 seems low but if I set the gain any higher, I sometimes get jerky stops at slow speed. Braking performance of truck and trailer is good so the lower setting appears to be working. Cheers to a fellow Airstreamer!
YES, all the different setting in the trailer tow screen have been check and/or tried. But will double check next time I hook up. Thanks
I have my factory installed brake control set on 9, all new brakes on 5th wheel, still not stopping very well.
Have tested volts to each wheel with some what consistent readings with hand slide control but with foot brake inconsistent readings
2020 super duty/2021 Keystone 5th wheel w/ electric brakes, 12k empty/15k loaded
I've tried different setting in the trailer tow screen with not much luck.
Just wondering what others have there's set at? Thanks
I suggest doing the break-in procedure @pjsinAK mentions In post #20. First, make sure you're getting proper voltage at the brakes. Then tighten up the brakes where they are just rubbing and go out and do the break-in procedure. If you do it, don't stop between sessions, just drive to allow the breaks to cool. Even though these trailers are towed hundreds of miles to the dealer lots, I've always found the electric brake works better afterward.
There is a Ford recall on the factory installed brake controller.
You were correct. Had my super duty at the Ford dealer today diagnosing power folding mirror not folding. They ordered a whole new mirror assembly.
They also said there was a notice about updating my trailer brake controller so they did that with the new program software update. Not a chance to tow with it yet but maybe that will help my situation. Thanks
So I did follow a break in procedure I found online for new brakes. And the update to my brake control from Ford seem to solve most of my problems.
camper stops much better now I’ve actually reduce the setting to eight. Still some inconsistency in the breaking effort but again much better.
Thanks, Jim. And glad to know it seems to be better.
