Sponsored by: Real Truck
p0183?
Old Sep 9, 2022 | 08:41 AM
Cessnapilot89's Avatar
Cessnapilot89
4wd High
p0183?
Hey Guys, my 2005 F250 5.4 2wd long bed just started throwing a P0183 code. Not other codes are present and the truck is not running poor or misfiring at all. In February a dealership in California replaced all plus and coil packs about 12,000 miles ago.
Now I know that P0183 is a fuel temperature error, but I was wondering what do I do to fix it? I can't seem to find a part for a temperature sensor and don't want to start replacing parts without fully knowing what is going on.
Thank you!
Old Sep 9, 2022 | 10:33 AM
projectSHO89's Avatar
projectSHO89
The P0183 indicates that the PCM isn't seeing a valid signal from the temperature portion of the sensor more commonly known as the FRPT (Fuel Rail Pressure-Temperature) sensor. On the schematics for your engine, the documentation calls it the IPS (Injector Pressure Sensor), oddly enough. Never came across that name/acronym before...
Anyway, check the connection for the sensor, especially the BK-YE wire that goes from that connector to the PCM. The sensor is located on the fuel rail on the driver's side.
After that, you could try a new sensor or, otherwise, follow the diagnostic procedure if you have the inclination and gear to do so.
Old Sep 9, 2022 | 02:46 PM
Cessnapilot89
4wd High
Thank you! Connection and wiring all looks fine so I am not totally sure how to diagnose it beyond that.
Tdizzle68
2004 - 2008 F150
May 29, 2022 09:15 AM
Carpenter Mark
May 27, 2020 12:53 PM
zzyzxroad
2004 - 2008 F150
36
Apr 10, 2019 09:33 PM
Unluckiest
2004 - 2008 F150
Mar 28, 2017 03:57 AM
Bootlegger's Deluxe
Modular V8 (4.6L, 5.4L)
Mar 12, 2016 08:51 PM
