What is an "S-Code" intake?
Old Sep 8, 2022 | 06:40 PM
DirtV2's Avatar
DirtV2
6th Gear
I have been looking into upgrading from a 2bbl to a 4bbl intake in my 69' F100 off and on for a while now. I am fairly sure it's a 390, as I measured the stroke at around 3.75". This afternoon I found a "S-code 4 Barrel" on Facebook Marketplace. The guy doesn't give many details other than "Fits FE block" and a picture of the casting number (C7AE-9125). I get the impression most FE parts interchange, so I am wondering if this will fit my application. My main concern, after research elsewhere on this forum, is cylinder head to intake port matching. Does that only relate to castings from earlier in the 60's? The casting number on my heads read C8AEH. Any and all help is appreciated.
Thanks,
-Dirt.
Old Sep 8, 2022 | 09:36 PM
85e150's Avatar
85e150
Decent stock manifold, will fit your engine. First seen--maybe--in the '67 Mustang.
Old Sep 9, 2022 | 01:48 PM
stryder's Avatar
stryder
The S-code will fit just fine. It will make a good torque in the lower rpm range, which is perfect for a truck. Not much in the way of high rpm power. If you're wanting power above 3500-4000 rpm, then look for a cast CJ intake or one of the aluminum Edelbrocks (not the sp2p).
Old Sep 9, 2022 | 04:59 PM
DirtV2's Avatar
DirtV2
6th Gear
Yeah I won't be building a high winding engine out of this thing any time soon (or maybe ever). I'm more of a "low end torque" kind of guy, so this will be just fine.
Thank you both for your time.
-Dirt
1976 F350
May 5, 2021 08:48 AM
jpouliot
Jan 4, 2021 07:52 PM
kilich
Nov 27, 2011 08:54 PM
Rusty_Old_F250
15
Jun 27, 2010 12:25 PM
lsrjf
Jul 30, 2002 12:10 AM
