Sponsored by: Real Truck
Crank/no start...Please help!!
Old Sep 7, 2022 | 11:00 PM
magnum2436's Avatar
magnum2436
Trailering
Working on a stock 2000 F350 Manual trans that i just put a used motor in.. Cranks over fine and starts on fluid (yes i know its bad lol) Changed every sensor, Had all the injectors tested, replaced the Hpop lines and new Hpop. I've cranked and cranked the IPR % goes right to 65% after 3 complete rotations and doesn't try to start at all not even a little smoke from the exhaust.. I have 3 of the same trucks and have swapped IDM computer ect and nothing changes.. Checked power/ohm ect at pigtails of sensors and all where it should be..new valve covers, compression is around 380psi on all cylinders.. all new injector O-rings no black in the fuel filter no diesel in the coolent/oil.. oil level good in both crank case and HPOP resivor.. around 30psi lpop while cranking.. ICP shows zero at all time.. unplugged icp also.. I ordered a IPR tool so im gonna try that tomorrow (9-8-22) Fuel pressure good and i also changed the engine harness just to see,I'm at a loss I've been working on the 7.3 for 15 years and this one has me up at night lol
Old Sep 8, 2022 | 12:47 PM
redford's Avatar
redford
FTE Leadership Emeritus
Your original post was moved to the 7.3L Power Stroke engine forum, where members are now trying to assist you. Please use that thread and not this duplicate.
magnum2436
35
Sep 12, 2022 09:17 PM
JNG6
Oct 25, 2021 09:50 AM
MickeyAkr
154
Jul 31, 2020 11:15 PM
LCA078
Apr 25, 2018 11:18 AM
Utah Jake
Jun 5, 2015 01:21 PM
