Ebrake issues.
Old Sep 7, 2022 | 01:13 PM
ahmad_f150's Avatar
ahmad_f150
Ebrake issues.
Hello,
I have new brake shoe, new hardware. Yesterday I put both rear wheels on jack stand and took the drum/disk/hat off.
Open/rotate the adjusting bolt at the bottom so brake shoe could expand a little. Put hat/drum back on. and tested it by engaging the ebrake.
It was holding rock sold. Then I put truck back on its tires, engage the ebrake again.. try to rock the truck its solid-jam.. the springs at the end of ebrake cables were completely compressed. I left the ebrake disengaged for the night.
This morning I engaged the ebrake and try to rock the truck.. it was moving back and forth no problem
Even when the springs are completely compressed...and struts/levers could not moved by hand... for some reason its not holding the truck. But It did last night when I finished the work.
I have taken tires/calipers/hat off many times these days,.. I wonder if I should take every thing off again to look.. or try to expand the adjusting bolt while every thing is on.
Last night I thought I had finally whole picture clear to me.. and ebrake was fixed for good... but this morning its lose again..
Old Sep 8, 2022 | 12:51 PM
ahmad_f150's Avatar
ahmad_f150
How much tension ebrake cable need in order to hold the shoe against the drum effectively ?
Even after applying ebrake if I pull hard I can find get some slack in the cable.. I never thought it was an issue since end-of-cable
springs get fully compressed.
Old Sep 10, 2022 | 04:54 AM
torq'ta 5 8's Avatar
torq'ta 5 8
You got to adjust them with the wheels/tires on ground, or adjust them tighter while on jack stand, stopping it from moving, with no weight on drum, verses the truck weight on drum will take more force.
One Sock
May 30, 2023 08:42 AM
tuxedobuttonquail
Sep 23, 2016 03:40 PM
sammie0126
Mar 30, 2014 03:59 PM
1957F100
Apr 1, 2013 04:33 PM
pickwick
Aerostar
Apr 15, 2003 07:36 AM
