Fuel Line swap
Old Nov 11, 2003 | 11:42 AM
79toquremonster's Avatar
79toquremonster
Question Fuel Line swap
The 79 i recently bought has a couple of leaks in the fuel line. I have fixed one of the leaks with a fuel line hose. Now i know i have another one and my friend has a couple of junk 79s some are 150 and i think one is a 150 but i was wondering if i could just take one off the junk truck and put it on mine? Also how much trouble would that be? I also am getting ready to order a new carb and intake and was wondering if i or if it would be easiser to wait to put it all on at once? Or it there is an eaiser solution to this problem that someone could tell me i'll be thankful Trucks are the same length.
Old Nov 11, 2003 | 12:06 PM
clean79150's Avatar
clean79150
I wouldn't use a fuel line from a junker, it probably has crud all through it. Fuel lines are pretty inexpensive, buy new ones to be on the safe side.
Old Nov 11, 2003 | 01:42 PM
KJKozak2's Avatar
KJKozak2
I agree. You'll probably find that the juned ones will fall apart when you try to remove them.
I'd just go to a parts store and get either some rubber fuel line or the steel stuff. As said before, it's pretty cheap.
Kevin K.
Old Nov 11, 2003 | 06:01 PM
79toquremonster
sounds good. Can i run a hose fuel line the entire way down the truck instead of metal?
Old Nov 11, 2003 | 07:01 PM
BigBully's Avatar
BigBully
I buy Aluminum fuel line by the roll from Summit racing products and Just use it for all the hard lines. Its easily bent to fit where ya want it to.
Old Nov 11, 2003 | 07:39 PM
chevdog's Avatar
chevdog
As a general rule of thumb, try to use the least amount of rubber line in the fuel system as you can. This will equate to a short section from frame mounted line to engine to compensate for engine movement, and maybe at the fuel tank, depending on how it's set up.
The steel or aluminum line will last for years of service. The rubber line needs regular replacement. To me, the extra dependability and safety is worth the extra work to put hard lines in.
Old Nov 12, 2003 | 08:34 AM
KJKozak2's Avatar
KJKozak2
Yeah, metal is definately better for longevity. Alum. would be best simply because of the rust factor with steel. However, I have a single rubber fuel line from the tank to the carb and haven't had problems with it yet. I also have an electric fuel pump in the back by the tank, and no mechanical pump at all.
So far, so good.
Kevin K.
Old Nov 12, 2003 | 09:01 AM
classic79's Avatar
classic79
BigBully,
Did you just use rubber and clamps to connect to the new al lines, or did you get some fittings to connect everything?
Has anyone tried any braided lines? I need to clean up my lines some in the engine compartment, too much rubber lines. I need to get a line from my mech. pump to a fp regulator mounted on the driverside about where a 2nd battery would go I have a box w/ an msd inside, and the regulator mounted to the outside of it. Then I need to make some lines from the regulator to both the carb inlet tube ( already have a mrgasket metal thing with fp guage on it) and to the fuel solenoid for the nitrous plate.
Though about the al line but wasn't sure how to hook it up to everything. The braided line should work with all the fittings, but its $$$$
Old Nov 12, 2003 | 09:08 AM
beartracks's Avatar
beartracks
A couple of notes of fuel safety. Steel line is best, it basically is forever if it doesn't get smashed. Rubber may deteriorate in 5 years and is not as strong of course. Braided line also has rubber insides and should be replaced every 10 years according to the manufacturer.
Aluminum: I use aluminum but there is one caveat. Remember that it is soft and secure it well. If it rubs on something it will eventually develope a hole. "Adele" type clamps with the rubber insert will also rot leaving metal to metal chaffing.
Anywho, be safe out there. Fix it right and fix it once.
Old Nov 18, 2003 | 09:04 PM
BadKarma's Avatar
BadKarma
If your budget allows it find an HVAC supplier and go the best way possible and replace as much of it with stainless steel, no rust ever and stainless holds up better to flexing.
BadKarma
Old Nov 19, 2003 | 10:36 PM
plowpusher's Avatar
plowpusher
get a tubing bender and some steel line at your auto parts store if you use rubber your just asking for trouble rubber gets hard and breaks or slips off gets pinched or can burst Stainless would be best but it's tuff to bend and expensive
Old Nov 19, 2003 | 11:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can use a double flaring tool to put a nice "bead" on the end of a tube to retain a hose. Just deform the tube with the first part of the double flaring operation. SS is best but it is harder to form. I would not use aluminum line, it cracks too easy from vibration. Copper tube is a major no-no also.
Old Nov 20, 2003 | 10:37 PM
jimlj's Avatar
jimlj
Hey Torque, just wondering,... Why is copper a major no-no? Come to think of it, I have never seen it used for fuel line. Does it not hold up to fuel? Too soft?
Old Nov 20, 2003 | 10:44 PM
Torque1st's Avatar
Torque1st
Posting Legend
It is just like aluminum and cracks easily. Not something you want for a fuel line. They use aluminum for some AC fittings because the pressure requires some fairly thick walls which helps resist cracking. Plus if it cracks only freon leaks, -not a danger like fuel. Steel or SS is really the only thing to use for fuel lines.
Old Nov 21, 2003 | 12:22 PM
Blaine's Avatar
Blaine
I used rubber back to front but encased it in that plastic corrugated stuff to protect it. Three years and no problem yet, but given some of the advice here I think I will replace it in the spring
