If I am going to pick one to believe, it would be Jim. The FFD injectors do not exactly have a stellar reputation.
I am glad you are running the 364.5. There has been some great info in the last few years about the effectiveness of the turbos. Probably a touch under sized but great knowledge on what it can be pushed to do. Prior to the dyno, how was driveability?
i assume Jim is the owner of rosewoods? I’ve got nothing bad to say about him, seems like a great company, but I haven’t heard anything bad about full force, is there another company you’ve recommend that offer larger injectors?
The 364.5 is awesome, I first had 160/30 with that turbo and it didn’t even compare to the stock turbo. Builds boost so fast. And will hold boost at lower rpm’s. Felt alittle laggy with 160/30s but I kinda like that ramp up feeling.
When I switched to 250/100, it was so responsive, it would built 10psi just in second gear if I got on it, and lit instantly. Seemed to like to be at like 30-35psi. I felt like it was leaving power on the table on the higher rpm….. egts are very cool, but if I floored it I could see 1400 degrees
Yes, Jim is the man at Rosewood. The only other one I would trust is Bitterroot. Both companies have stellar reputations are willing to engage with their customers.
No partial hp goal just would like to make more power than current set up which dynoed at 480hp. I like rosewoods, no complaints on my injectors, he just won’t go any bigger. Does bitterroot sell injectors of there own?
