Bronco II Ford Bronco II
engine not running right
Old Nov 11, 2003 | 11:21 AM
english guy's Avatar
english guy
Unhappy engine not running right
1988 bronco 2 4x4 2.9Ltr manual gearbox
can anyone help me out heres the problem:
ive sorted out the non running problem( broken earth wire from FP relay) with the engine running when i put my foot down on the gas the engine starts to die but doesnt stall but when i lift my foot off the gas the revs increase ???? is it possible gas starvation is there any checks i can do to check out this problem
Old Nov 11, 2003 | 03:52 PM
Ken00's Avatar
Ken00
Check fuel pressure KOEO 35-45, KOER 30-40, volume 6 oz/ 5 seconds.
Old Nov 11, 2003 | 09:14 PM
Gutter's Avatar
Gutter
yep she is boggen out on you, change the fuel filter and adjust carb according to factory specs. use some carb cleaner and use according to can instructions . however they are very bad for carbing up in the intake you will know espesially in cold weather,
when the carb ports ice up.
remove intake and have a look at the exaust ports all of them but especially under the carb, these ports were disgned to fowl up and not heat the carb as it should.
let me know.
Old Nov 11, 2003 | 09:21 PM
Ken00's Avatar
Ken00
FYI Gutter, the 2.9s are fuel injected, no carbs.
Old Nov 11, 2003 | 09:26 PM
Gutter's Avatar
Gutter
sorry i was thinking of my old piece of crap 84 still check the fuel pump sounds shot
Old Dec 31, 2003 | 02:28 PM
Trixster's Avatar
Trixster
Have you tried injector cleaner?
Old May 9, 2004 | 06:23 PM
lou cav's Avatar
lou cav
Smile
I had a similar problem, I tried everything from changing the distributor to map sensor and coil,new cap rotor plugs twice. the pickup on the distributor. just the other day it died on me when i was driving and i was looking under the hood and heard a clicking from the egr relay thats on the pass side fender next to the starter selinoid.it has the green and red vacuum lines on it plus a elec plug on it. I disconnected it and it wouldn't start, I went to my local junk yard and they told me that won't help, I took the shot anyway, I got it for ten bucks, installed it and it's been running great ever since.
bandhauler
Aug 28, 2012 08:54 PM
zer0321
Feb 22, 2011 09:03 AM
mandylynn1978
1997 - 2003 F150
Feb 3, 2011 12:28 AM
nosbor
May 29, 2004 11:59 AM
Sleepy Paul
Jul 26, 2003 02:25 PM
