Axle Width
Old Sep 2, 2022 | 01:07 PM
RTT's Avatar
RTT
Question Axle Width
Will 1964 Fairlane rear axle work ok under a 1971 F100 ?
Old Sep 3, 2022 | 04:17 AM
Crop Duster's Avatar
Crop Duster
I would say no. I don't know the wheel track but that would be the least of your problems. The spring seats would not line up. The brakes would be smaller, and the wheel lug pattern would not be 5 X 5 1/2. Plus, unless it was in a 289 4bbl car it will most likely be an 8-inch rear with a different yoke than a truck.
If you need the entire housing or even parts for yours, you need to find a 68 to 72 truck. You can use a 73-79 truck but you have to move and reweld the spring seats. They are about 3 inches wider so it will set the tires out some.
Old Sep 3, 2022 | 01:16 PM
RTT's Avatar
RTT
Thank you Crop Duster. You gave some very good information.........
I completely forgot the wheel pattern size !!!
maverickfe390
Sep 22, 2010 01:15 AM
