Wiring harness
Old Aug 30, 2022 | 08:51 PM
chuck3908's Avatar
chuck3908
Trailering
Wiring harness
I have a 68 f100 original had a 360 and I’m looking at wiring diagrams and everyone I have seen show a 3 fuse fuse box but mine has five fuses. The 1970 diagram looks a lot like mine so does anyone have an idea what I should do? I want to purchase a new harness and rewire my truck but not sure which harness to get. Thanks
Old Aug 31, 2022 | 01:05 AM
1TonBasecamp's Avatar
1TonBasecamp
The five fuse panel in the diagram is the most common that I’ve seen. Personally don’t remember any three fuse panel.
Got a picture of it?
Does anyone make a reproduction wiring harness for your truck? Or for any of these trucks yet?
And do you want it to be a concourse restoration, or would upgrading the harness to something more modern be an option?
Old Aug 31, 2022 | 09:01 AM
fe390pc's Avatar
fe390pc
Take a look at this.
https://www.fordification.com/tech/w...terdiagram.jpg
Old Aug 31, 2022 | 11:38 AM
1TonBasecamp
Sounds like somebody swapped out an original for something different.
Old Sep 1, 2022 | 06:21 AM
Makeryguy's Avatar
Makeryguy
This is interesting because my 70 has a 5 fuse panel, but the laminated wiring diagram I got for my 70 shows a 3 fuse block in the diagram. It's at the shop- I'll post a pic later!
Old Sep 1, 2022 | 07:49 AM
1TonBasecamp
Does this diagram with the 3-fuse panel show it looking the same as a 5-fuse panel? Same shape and size in other words?
You may be looking at a diagram showing one branch. Such as switched circuits only, or constant circuits only.
With three, probably switched.
I’ve seen that in more modern diagrams where they had separate images of the fuse panel, or just one image showing switched only, and then the constant power fuses were listed separately along their circuit pathways.
The smallest fuse is the one for the instrument cluster illumination which is only hot when the headlight switch is turned on. does your diagram indicate that particular fuse?
The older diagrams for the Broncos all show five fuses in one unit all the way back to’66, but I have seen versions that separate them out for the full size trucks.
tjewitt21
Mar 28, 2014 11:50 AM
SuperDuty93
13
Dec 20, 2013 11:44 AM
78ford351m
Aug 19, 2006 05:48 AM
Blue50F-1
Electrical Systems/Wiring
Jun 25, 2006 02:00 PM
dan68
Oct 21, 2003 10:48 PM
