Offroad & 4x4
Manual hub conversion
Old Nov 11, 2003 | 09:26 AM
98f1504x4ohio's Avatar
98f1504x4ohio
has anyone put manual hubs on newer style 1/2 tons? I know that warn makes a kit for dodges and jeeps, but I am unsure about Fords.
Old Nov 12, 2003 | 10:32 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
I don't think they make hubs. The 97 and newer don't use any type of locking hubs (f-150s). I believe it locks into 4x4 at the differential.
Old Nov 12, 2003 | 11:19 PM
kspilkinton's Avatar
kspilkinton
Yep, a electrically controlled, vacuum actuated, center axle disconnect. The outer hubs are similar to the ones found on the trucks rear end, locked unless you break the axle...
-Kerry
Old Nov 13, 2003 | 10:56 AM
Jimmy Dean's Avatar
Jimmy Dean
Is this a good thing or a bad thing?
Old Nov 15, 2003 | 01:59 PM
kspilkinton
Depends on what you mean. It's good that you'll never have to worry about the vacuum engagement of the hubs, but you'll still have to worry about the vacuum engaging the axle. Ford solved one problem, but they introduced the potential for another.
-Kerry
