Too Restrictive?
Old Nov 11, 2003 | 07:14 AM
bigwheelin's Avatar
bigwheelin
Too Restrictive?
Hi guys
I have got the motor in the truck and have a question about exhaust. I have a head pipe from an EFT truck cut off right after the H. I was thinking about using that and running 2 1/4" the rest of the way back. Do you think that head pipe is to restrictive? Heres my setup and thanks for the info.
Bob
-300CI .040 over
-9.5: Comp. Ratio
-Crane Truck Power Cam
-Port Polish Head With High Performance Vavle Job
-Offy DP
-Carter AFB 625 CFM Carb
-EFI Manifolds
Old Nov 11, 2003 | 09:40 PM
optikal illushun's Avatar
optikal illushun
the EFI manifolds flow better then stock but there is no replacement for a good set of headers. but they should do fine. with the much engine work, u probaly can run 2 1/5 or 3" exhaust all the way back.
