Knocking/missing
Old Aug 23, 2022 | 04:32 PM
MichelinNation's Avatar
MichelinNation
2nd Gear
Knocking/missing
Hello all! New to forums (for posting, not reading lol). I recently bought a 2010 f150 lariat for a cheap price and originally planned just to take the interior out and to put in my daily driver XLT model.
This truck was a ramp side airport truck so it has little rust and only 118xxx km’s. But unfortunately a lot of idle hours. I took it to a garage to have it looked over and was told it wouldn’t need much to be road worthy. I then decided I would flip this truck.
fast forward…
truck would miss on multiple cylinders and coolant was being leaked somewhere and it wasn’t on the ground. Replaced the intake manifold/thermostat gaskets and replaced the plugs and that issue seems to be fixed as the coolant level isn’t decreasing. Not getting any codes for a misfire.
it currently got a parasitic drain on the battery that is coming from the audio control module. Replaced the stereo in it to trouble shoot and will update if this fixes the problem as I’m sick of pulling the fuse or disconnecting the battery when I’m done with it.
Done a oil change and the dip stick is showing correct oil levels.
this truck now starts and a loud “tick tick tick…” is heard from the driver side. After about 30seconds to a minute it goes away and the truck is fine. Take it for a drive and get it going at speeds more than 80km once come back to slower speeds and idle speeds it makes a loud knocking and sounds like it’s missing on multiple cylinders. I have a video of it and will post if we are able to?
I have unplugged the vct solenoids and it do seem to make a slight change but don’t fix it. While it’s in this little episode of bucking and knocking it won’t throw any codes but if you rev it up it will go away and idle without a hitch.
thanks in advance
File Type: mov
Old Aug 24, 2022 | 08:15 AM
gDMJoe's Avatar
gDMJoe
Exclamation
MichelinNation...
Welcome!
Vehicle Information Engine? And... If it's a 4.6L - 2V or 3V?
Consider putting your complete vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, maintenance, modifications, etc., etc.) in your signature to have it automagically included when you post. *Eliminates playing 20 questions when/if a post is made pertaining to your vehicle.
» Edit Signature ««« -click-
*Don't forget to [ save ] it.
Old Sep 3, 2022 | 04:09 PM
MichelinNation
2nd Gear
It’s the 5.4l
Originally Posted by gDMJoe
Welcome!
thanks for the reply, sorry for my delayed one. It’s the 5.4l. Just replaced the vvt solenoids and didn’t help. However when I hauled the valve covers off it look very dry and ALOT of crud. I’ll attach pictures.
I can’t recall when I started to hear this tick noise that is definitely coming from the valve components but I’m thinking it may have been noticed after I done an oil change, now it wasn’t synthetic oil and I believe it’s just the basic white oil filter. Can this contribute to the problem? I currently do have sea foam in the oil port to help clean it out before I drain the oil and replace that and the filter.
It’s weird, I start the truck and it’s the tick tick tick noise, press the gas and it idles smooth and quiet. Drive it and you can get the tick louder as you press the gas. Potentially needing the cam phasers done?
Old Sep 4, 2022 | 09:15 PM
explorerdriver's Avatar
explorerdriver
Rockers/followers are a huge problems on this engine. The roller gets play, eventually it will fall out or destroy the cam.
. There is even a TSB.
deezdrama
1997 - 2003 F150
34
Jan 10, 2020 10:43 PM
Mach5
Modular V10 (6.8l)
Dec 28, 2019 08:34 PM
spiggy769
Modular V8 (4.6L, 5.4L)
Jan 9, 2013 11:30 AM
reptile80
3.8 & 4.2L V6
Jun 19, 2011 04:28 AM
fmjnax08
1997 - 2003 F150
Feb 2, 2011 07:31 PM
