Wiring help needed,
I have a few wires here I'm not sure what to do with. Tad and Tab are in the same wire sheathing the one with black/red is concerning cause that's the color wires for the injectors.
Then one more black and red by it'self
Any and all information y'all may have please post. The truck does run good and is my daily driver. Check engine is on so I assume it will be EGR and all emissions related codes. I'm going to read those now
TAB, TAD and EGR solenoids are in that area as well as the air temp sensor. Up front you have TPS, IAC and coolant sensor. Is something not plugged in?
No tab or tad
No pcv or egr
Is the connector that looks like it should plug in to a fuel injector on a long harness by itself? It could go to the power steering pressure switch. Is the the air conditioner compressor plugged in? Sorry about the guessing but I don’t have my Haynes manual here to look up wiring schematics.
The PCV valve would not be visible from that picture. It is in the top of the valve cover at the #4 cylinder and the hose connects to the upper intake plenum either at the back by the firewall or the top center. In either case there is no electrical connection.
