07 E350 disconnect battery
Old Aug 21, 2022 | 08:22 PM
tabijan's Avatar
tabijan
I just noticed a warning on the radiator support that this van has a secondary battery that has to be disconnected separately. Where and how do I disconnect the secondary battery? I see videos on replacing the battery. I’m just wondering about disconnecting the battery before doing electrical work.
Sixto
07 E350 5.4 183K miles
Old Aug 21, 2022 | 08:54 PM
T-wood's Avatar
T-wood
When you disconnect the battery under the hood you will see how the frame mounted battery also connects to that main terminal.
With mine i can remove the main terminal from the underhood battery, then i also remove a 1/2" nut to disconnect the frame mounted battery from the main terminal. This is how i disconnect both and can charge ea individually if needed.
Desert-Rat
21
May 9, 2023 04:48 PM
JoePa2
17
Jun 28, 2020 10:31 PM
JoePa2
Oct 21, 2011 11:34 AM
rshawiii
Electrical Systems/Wiring
Jun 24, 2004 12:49 AM
