Hellwig Helper Spring Adjustment Questions
Old Aug 20, 2022 | 10:19 AM
Verdigo's Avatar
Verdigo
8th Gear
I have an 85 27ft Class C Motorhome I would like to lift a bit in the rear. It already has helper springs in the rear. Not sure if the manufacturer installed them or the PO. It has very little actual use, (Under 8000 miles) but was in storage most of it's life just the same setting on these springs 37 years. I had seen a thread elsewhere where it was posted adjustment of the outer U bolts was possible down to 1/4 inch. If that is the case I have lots of adjustment left, but that didn't smell quite right so I am trying to get the benefit of this pool of experience.
Thanks in advance
Old Aug 21, 2022 | 05:13 AM
JWA's Avatar
JWA
I'm not familar with Hellwig's helper springs but if you have any questions they're usually easy to contact and answer you. If there are any Hellwig part numbers visible or a tag that will be important to have ready to share.
You might also check out their site for technical articles they might have posted for situations like this.
Good luck and please let us know how this works out for you.
Old Aug 21, 2022 | 10:27 AM
tabijan's Avatar
tabijan
Oops, misread original post.
Rubiranch
16
Nov 16, 2021 09:35 AM
swampthang
Apr 24, 2016 02:25 PM
460 FORD MAN
66
Jul 18, 2012 04:35 PM
Tim Young
1966 - 1977 Early Broncos
Jan 28, 2007 08:43 AM
PowerstrokeJunkie
Dec 5, 2006 10:23 PM
