Stalling with a/c on
Old Aug 18, 2022 | 09:37 PM
staink's Avatar
staink
1st Gear
I have a 1978 f100
past month:
rebuilt carb- (then professionally tuned)
new coil, spark plugs, gas filter, oil filter, gaskets, manifold bolts
PO had vintage air installed
ran amazing for a week and now it’s having problems. Sounds okay in neutral but stalls when in park, drive, reverse. Runs rough and kinda lurches a few times when stationary before engine shuts off. I noticed that when I turn the ac off I have no issues. Since I just had it professionally tuned i dont think it’s a carb tuning issue. I have no idea what could be the problem though.
also, today I turned the ignition off and removed the key but then engine stayed on and was kinda sputtering at slow rotation. Had to turn the ignition a few times to get it running normal before it would shut off properly. No idea if the problems relate. It stalled several times after going home and I had no issue starting immediately when I turned the ignition tho.
Old Aug 18, 2022 | 10:47 PM
440 sixpack's Avatar
440 sixpack
Sounds like you're dieseling, higher octane helps.
You may have an idle speed solenoid on your A/C kit holding the throttle open more. is should shut off with the key but if it's not it would cause your symptoms.
gray035
32
Mar 14, 2017 07:15 PM
jrmurphy77
Jul 4, 2011 01:53 PM
I'minthegarage
Mar 23, 2009 01:39 PM
aa3
Jan 22, 2005 09:26 PM
