HELP!! I have a F-350, trailer, CDL question
Old Aug 18, 2022 | 06:59 AM
Grass Lake Ron's Avatar
Grass Lake Ron
Originally Posted by 1olddogtwo
Now that's a new one to me.
So a F-450pu @ 14k and say a gooseneck with a 40K is legal in MI for non- commercial use?
Michigan is regarded as one of DOT enforcement states too.
OP, need more details, all the details.
Also, you just can't get a CDL without schooling anymore.
Strange, but true.....and don't be a pound over. Also make sure if your not private to have your CDL and stay in your load range. I read and researched on this and called both the SOS and the State Police. Both said I could run the F350 to it's max and no more for private use only without a CDL. So I ordered a 350 rather then a 250. Michigan already has high insurance rate so mine didn't go up. One other thing to consider is Michigan has a high weight load on the roads. That's part of the reason they are looking at weight more then anything else. I said in a recent post seeing the state Police pulling over a diesel 250 with a goose neck and 3 trucks on a 40' trailer. DOT numbers or not, he was over his gcvw.
Old Aug 18, 2022 | 08:48 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I was going to say, yeah as long as you're not overweight, if it's for personal use you don't need a CDL in Michigan to run an F450 pulling basically anything. My dad and FIL have been doing it with their toy haulers for years.
Old Aug 18, 2022 | 09:02 AM
Grass Lake Ron
At least in Michigan there is no reason to buy a 250 diesel and chance it. I still see a 15 to 1, 250 to 350, on Michigan roads pulling well over their weight. It's asking for trouble....
Old Aug 18, 2022 | 09:41 AM
Desert Don's Avatar
Desert Don
And in *MOST* states, RV’s are exempt from any special licensing, regardless of weight or tow rig. That’s why at times you will se a big 5er being pulled with a Peterbilt.
Goosenecks, box trailers, flatbeds, etc *MIGHT* fall into a different category, depending on regs inb a given jurisdiction.
Old Aug 18, 2022 | 12:04 PM
1olddogtwo's Avatar
1olddogtwo
Link?
I've never seen a state give over 26,000 lb for personal, some states don't even give you that much off the top.
Is most of you know I run a commercial hot shot type business. I won't pretend to know about the lawless RV group..... Even though I do have two RV's in my fleet. They are they are considered a commercial vehicle and have DOT's on them along with ELDs.
Old Aug 18, 2022 | 12:07 PM
OBS460's Avatar
OBS460
In Alaska you can drive/register a Peterbilt as a regular vehicle IF it is for private use without a CDL. There's a couple running around.
Old Aug 18, 2022 | 12:23 PM
1olddogtwo's Avatar
1olddogtwo
I believe you can that anywhere. The tractor itself is under 26K and no endorsement for air brakes.
Most people believe CDL is needed at 26,001 when in reality, you can go up to 36,000.
Old Aug 18, 2022 | 12:43 PM
Keokie's Avatar
Keokie
Link?
Why is the RV group lawless? What laws are they breaking? Any links you can provide?
Old Aug 18, 2022 | 12:57 PM
1olddogtwo's Avatar
1olddogtwo
Typo, Lawful
Old Aug 18, 2022 | 01:11 PM
Keokie's Avatar
Keokie
Typo, Lawful
Ha! I chuckled at that.
Old Aug 18, 2022 | 01:15 PM
OBS460's Avatar
OBS460
Apparently not as people are stating different license plates/registration required depending on gvwr and insurance companies won't touch an F450 or f550 and above in their statea. A Prius and a Peterbilt have the same everything if for private use here.
There is also no maximum like 26k, 36k before a cdl is needed.
Old Aug 18, 2022 | 01:24 PM
Keokie's Avatar
Keokie
Typo, Lawful
Old Aug 18, 2022 | 03:06 PM
  #28
99powerstrokedF250
I think what he was getting at, or the way I understood it (and frankly have always understood it) is that RVs, despite being big and heavy, in most states do NOT have to follow the same rules as trucks. They are basically exempt from the rules that they'd have to follow if they were running as a business.
Which is kinda bizarre, if you think about it. We literally allow people to hitch up and tow, or jump in the driver's seat, of equipment that they likely have had no experience or training with, that in the trucking industry would require special licensing to operate, and let them go.
Old Aug 18, 2022 | 03:14 PM
  #29
Joe T's Avatar
Joe T
I think federally private use is exempt up to a certain weight of axle. Its astronomical like 80k or something. And also over a certain number of passengers I believe.
The OP should check his state licensing website
Old Aug 18, 2022 | 03:55 PM
  #30
Desert Don's Avatar
Desert Don
Private use still has to go by the maximum weights. 20,000 per single, 34,000 per tandem. Multiple axles gets into what is known as the “bridge formula”. I.E. how far apart axles groups are spaced, total number of axles, etc. Of course, pickups are never going to get close to those weights.
