Weeping diff cover?
Old Aug 13, 2022 | 10:19 PM
tabijan's Avatar
tabijan
Weeping diff cover?
I set out to change diff oil and found this -
Is oil sweating out the diff cover at resting level? I suppose better than all around. The level was a touch low but as clean as new. We got the van at 170K miles from a fleet owner.
Sixto
07 E350 5.4 183K miles
Old Aug 14, 2022 | 04:19 AM
FinnishStroker's Avatar
FinnishStroker
Sure that it ain't coming from the tubing..?
Old Aug 14, 2022 | 04:24 AM
JWA's Avatar
JWA
To my eye that leakage is indeed coming from the differential cover---it doesn't appear to be from the axle housing tubes. I'd remove the cover, thoroughly clean the gasket surfaces and use either a "heavy" dose of RTV or a LubeLocker gasket which should stop that small leak.
Do make sure the differential cover is completely flat around its edge to further assure a good seal.
Old Aug 14, 2022 | 08:10 AM
manicmechanic007's Avatar
manicmechanic007
That is coming from then tube
There is a big rubber seal in there and some axles use silicone
The plug weld is the leak
You clean all that grease off spotless, and seal it externally with clear silicone in those plug holes
Good luck
There is a TSB on this
Old Aug 14, 2022 | 09:36 AM
tabijan's Avatar
tabijan
Do you mean those round things at axle level on either side of the pumpkin case outboard of the diff cover? I’d be tempted to tap in a freeze plug or force a threaded plug into those holes if it’ll slow the leak.
Sixto
Old Aug 14, 2022 | 01:37 PM
manicmechanic007
Yes, It is common for those to leak a little
The Ford bulletin had us clean it all off and wipe clear silicone sealer around in there
They figured the welds were porous
dvldog458
Oct 2, 2010 09:08 PM
Brown Falcon
Apr 20, 2009 04:26 PM
ech0sh4y
2004 - 2008 F150
Sep 30, 2007 11:03 AM
jays power stroke
Sep 12, 2007 09:25 PM
Reidicus
Oct 19, 2006 08:12 AM
