Lower fuel filter
Old Aug 11, 2022 | 09:21 PM
mustang9701's Avatar
mustang9701
Lower fuel filter
Anyone ever have the lower filter not line up? when it hits the stop, the plug for water in fuel won't reach. 2012 .....had to actually back if off the stop to plug it in. This doesn't seem normal.
Old Aug 12, 2022 | 05:15 AM
senix's Avatar
senix
No it is not normal.
Are you using OEM fuel filters?
If you are not at the stop then you will probably have air or a fuel leak.
I would suggest you take it back off, look inside the housing and inspect the filter and o ring.
Old Aug 12, 2022 | 05:38 AM
HeavyAssault's Avatar
HeavyAssault
Without pics I'd say you broke off the stop that's part of the frame housing.
Old Aug 12, 2022 | 06:53 AM
mustang9701
Yea they are oem filters. I have 2 other caps that do the same thing. Broken stop on the housing may be the issue. I been concerned about the caps.
we backed it off to where it normally would stop and started the truck to see if it would leak or even start.
it started fine and no leaks. Just nervous something will end up happening
Old Aug 12, 2022 | 06:55 AM
senix's Avatar
senix
So it would appear you can run it until you get a replacement and do the install.
Obviously, be careful with the install process from this point forward.
Old Aug 12, 2022 | 11:02 AM
cj45lc's Avatar
cj45lc
You will be fine, the stop has been broken on mine since I bought it. I've changed filters 3x with no leaks, I just count the turns when removing & put it back the same amount. The way that thing seals I would bet it would have to be off a couple of turns before leaking. Got a new cap on the shelf & will change it one day lol
makuloco2000
Dec 6, 2013 02:52 PM
artfd
Jan 1, 2012 08:13 PM
Farmboypowerstroke
Jan 1, 2010 08:58 PM
61 uni
Nov 22, 2008 08:20 AM
Finally
Mar 24, 2005 07:12 PM
