radiator cowl
Old Nov 10, 2003 | 09:01 PM
ford55truck's Avatar
ford55truck
radiator cowl
My '55 223 gets almost hot when idling at a light. Someone changed the fan blade to a 6- blade but it doesn't have a cowl from the radiator to the blades. Is this normal?
Bear with me, I just got my truck last Thursday and this is new to me. I have been a Chevy man my whole life but this absolutely original truck was too good to pass up and I am totally enjoying it. I intend to keep it stock, as much as possible, as you don't see many around. I would surely like power assist steering though being 60 and it drives like a truck. LOL
thanks all, Tom >again<
Old Nov 11, 2003 | 06:02 AM
bigwin56f100's Avatar
bigwin56f100
Tom,
I dont think the 6 cylinder trucks came with a fan shroud. Check and make sure the fan is on correctly, make sure its pulling air in not pushing air out back thru the radiator. the fan blade should only be about an inch from the radiator.
Kevin Bigwin
Old Nov 11, 2003 | 06:48 AM
55Bubba's Avatar
55Bubba
At the risk of being obvious, have you considered some other possibilities?
1. Water pump
2. Fan belt tension
3. Thermostat
4. Clogged radiator
At this timeof the year, you should not be having overheating.
Bubba
Old Nov 11, 2003 | 09:30 AM
ike55's Avatar
ike55
Re: radiator cowl
Tom,
I have an original '55 that has been in the family since new. I don't remember a fan cowl ever being on the radiator. Putting one on might help but would only be a bandaid. You obviously have some problem that should be fixed. The suggestions listed by the other posts should guide you in the right direction.
As far as power steering, there seem to be some choices out there, but I would try different tires first.
Good luck!
Old Nov 12, 2003 | 05:08 PM
Scot's Avatar
Scot
There was a shroud standard or atleast available for thhe 6 cyl. It will not interchange with the V8 shroud.
Old Nov 12, 2003 | 05:59 PM
dandman's Avatar
dandman
I have always heard that heat is the biggest thing to fix on any 53.4.5.6. Higher flow water pumps, three core radiator, new high quality hoses(bottom hose colapses) with internal wire support, are all easy fixes that don't take away from stock look.
