6.2L V8 Discuss the 6.2L V8
Exhaust Manifold Replacement
Old Aug 8, 2022 | 07:39 PM
kehinnc's Avatar
kehinnc
My 2012 F250 has a cracked driver side manifold. Truck has 100,800 miles on it.
How difficult is it to replace if none of the studs break? A lot of hours?
The Ford manifold is about $130 plus gaskets, bolts and studs if needed
Thanks
Old Aug 10, 2022 | 09:30 PM
leadmic's Avatar
leadmic
Thanks
I did the passenger side on my 2011. I had to remove the wheel and tire and pull the inner fender out. I needed to loosen the driver's motor mount and remove the passenger side mount and drop both head pipes. I didn't brake any studs, but I had to jack the engine up quite a ways to get enough clearance to get the manifold between the studs and frame. I left the driver's side motor mount connected but lose that way when I jacked the passenger side it would pivot up on the passenger side. I bought a doorman manifold and gasket I also used some high temp silicone on both sides of the gasket to make sure it sealed well. The doorman manifold looked just like the factory Ford manifold that I took off except where the Ford part number was cast at on the doorman it had been ground off. I suspect they were both Ford manifolds.
LVExp
Jul 10, 2019 09:42 AM
rhjj
Sep 5, 2016 07:05 AM
Clint S
1997 - 2003 F150
Nov 18, 2010 12:58 AM
Shasta69
Modular V10 (6.8l)
Nov 2, 2007 10:16 PM
jutahh1
Modular V10 (6.8l)
Jun 18, 2007 09:42 PM
