Air Filter System Fault
Old Aug 8, 2022 | 09:17 AM
Great Danes's Avatar
Great Danes
I have the Air Filter System Fault in the Maintenance Monitor display. I have had it last year sometime and it went away on its own, but now it seems to be hanging around for a few months. No issues with operation of the truck, warning lights etc, just a bit annoyed that the message is there.
Any ideas on what I should check? Air filter is new.
Old Aug 8, 2022 | 09:26 AM
redford's Avatar
redford
FTE Leadership Emeritus
What is your air filter restriction gauge indicating?
Old Aug 8, 2022 | 02:01 PM
morehouse7's Avatar
morehouse7
Air filter is new as in you just changed it? And the warning has been on ever since?
Old Aug 8, 2022 | 02:48 PM
jollyrogr's Avatar
jollyrogr
I got this error once after turning the key on to test my new LED lights but without the air box installed. There was no code set or CEL. I reset it by clearing all DTC's with Forscan.
Old Aug 9, 2022 | 12:04 PM
Great Danes
No restrictions showing as the filter is new.
The error showed up before I swapped the filter recently, so it's not a result of the filter change.
I will give this a try and clear all codes to see what happens.
Old Aug 11, 2022 | 01:10 PM
Great Danes
Well, I went in to clear codes and nothing was found so there was nothing to clear and the error still persists.
I really don't want to have take this the dealer so any additional input would be appreciated,
Old Aug 11, 2022 | 01:31 PM
morehouse7's Avatar
morehouse7
Did you run the function to clear codes? Or didn't do anything?
Old Aug 12, 2022 | 07:22 AM
Great Danes
Since there were no codes stored, it did not allow me to clear anything.
Old Aug 12, 2022 | 09:55 AM
Keokie's Avatar
Keokie
Maybe a bad sensor? Also, you might try disconnecting the battery for a few minutes.
Old Aug 12, 2022 | 09:03 PM
morehouse7's Avatar
morehouse7
An APIM reset worked for someone using Forscan with your issue, not sure what trouble that may cause you.
bluefishgary
6.7L Power Stroke Diesel
Dec 28, 2020 09:13 AM
ibewshooter
2015 - 2020 F150
18
Apr 25, 2016 01:10 PM
Technologiq
Aug 29, 2013 08:43 AM
150ford
Jun 20, 2005 07:59 PM
