Brake booster
Old Aug 6, 2022 | 12:10 PM
Prionus's Avatar
Prionus
Brake booster
The brake booster can be replaced without disrupting the master cylinder, right? In other words, I won’t need to bleed the brakes after replacing the brake booster, right?
Old Aug 6, 2022 | 12:30 PM
Yendra Built's Avatar
Yendra Built
There is usually is enough space to slightly bend the brake lines out to get the master cylinder off of the studs in the booster and hang there.
Old Aug 6, 2022 | 03:16 PM
Prionus's Avatar
Prionus
Thank you. That’s what I thought.
Old Aug 6, 2022 | 06:10 PM
Franklin2's Avatar
Franklin2
Just make sure the rod between the master cylinder and the booster, stays in the booster. They will probably have a warning on the rebuilt booster to not pull it out.
Old Aug 7, 2022 | 12:22 AM
Ken Blythen's Avatar
Ken Blythen
With the change of booster you may also need to adjust the pushrod length.
I think the Chiltons/Haynes manuals specify around .995" of stick-out, or something like that.
But when I replaced both my booster & master cylinder a while ago, that measurement did not work & left the pushrod with some preload on it.
This situation can mean that the brakes drag & overheat.....there needs to be very slight clearance to ensure the master cylinder piston can fully return.
Here's a good video explaining the adjustment from around 31:50.........
Old Aug 7, 2022 | 09:52 AM
FuzzFace2's Avatar
FuzzFace2
On my new booster that rod adjustment was left loose and if I did not find that I think over time it would have loosen up.
Dave ----
Old Aug 9, 2022 | 12:37 PM
cadunkle's Avatar
cadunkle
Also be sure to check for any wetness or signs of leaks from the master cylinder. If it's leaving out the end of the bore it'll kill the diaphragm in the new booster. Easy to change just the booster though. I did mine a few months ago. I recommend painting the new booster if it is not already, keeps it from turning into an ugly ball or rust right away.
Chicago Fire Patrol
13
Aug 8, 2022 04:37 AM
Landman 454
Oct 12, 2021 01:46 PM
man7sell
1961 - 1963 F100 Unibody
Jan 26, 2018 09:23 AM
68bluebeast
Nov 5, 2007 01:20 PM
