Rear Axle upgrade
Old Jul 26, 2022 | 11:14 PM
07Rangernewbie's Avatar
07Rangernewbie
2nd Gear
Rear Axle upgrade
So I’m new to the upgrading my truck and I need some help. I have a 2007 Ranger 3.0 2WD. I am wanting to lift my truck, keep the rim size at 15”, and increase my tires to a 32”. My question is would I need to re gear the rear diff? if I do which ratio or axle should I go to?
Old Jul 27, 2022 | 10:01 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
You can calculate the effect a larger tire diameter will have on your performance, acceleration and fuel economy. You probably want to increase to a 4:10 ratio. What tire you have now, what is the axle ratio and is your Ranger M/T or A/T?
Old Jul 27, 2022 | 11:13 AM
07Rangernewbie
2nd Gear
I currently have a 225/70r15 and the axle ratio is 3.73 with A/T tires
Old Jul 27, 2022 | 07:22 PM
Conanski's Avatar
Conanski
Do the lift and tires first and don't forget to recal the speedo, then decide if it needs more gear. Our 04 has 4.10 gears with the M5OD and 235/75R15 tires and I wouldn't hesitate to run 31's or even 32's with this combo.
Old Jul 28, 2022 | 10:04 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Look inside the wheel to read the wheel width. It is probably 7". If you go to P27570/15, the sidewall will grow 1" on each side and the diameter will be 31.7" When Rangers offered P265/75R15 tires, they restricted that to 4.0L and 3.73 axle because of the lack of performance the 3.0L displayed with larger tires. You can try the lift and tires and then decide if you can live with the 3.73 or look for a 4.10 to swap.
dans 51 f2
Mar 17, 2010 03:44 PM
Rifleman7.62
Jan 18, 2004 09:00 AM
pocket59
Jul 30, 2003 07:10 AM
Kidd
Jul 15, 2001 04:57 AM
