I've got Fox 2.0's on my 2018 F 250. Got a little over 52K miles on them. I'm thinking based on the ride I'm now getting that its time to replace / have them rebuilt.
Any thoughts out there on getting another set of 2.0's versus going with another product.
Mostly driven on the street and used for pulling my trailer. I do some mild to moderate off road driving.
if the shocks have a nitro refill valve...might be worth the time to check the pressure.
50K miles on the shock while in street use doesnt sound like they are at the end of the line to me.
I would clean them up and put them on craigslist and disclose the miles. someone will buy them.
I can have them rebuilt for $75 each plus shipping. All in with discounts paid $689 for the new ones. I do a lot of RV towing and the roads in CA are pretty bad.
Probably the last couple of thousand of miles I noticed that the ride was just not as good / compliant as before....
Don’t mean to highjack this thread although I do think it relates to OP’s original question. I also mostly tow trailers on the highway with my truck. Has 112k miles on the original shocks (they’re done!). Running stock size tires (18’s), stock suspension etc. How do the Fox 2.0’s compare to Bilstein, Rancho etc as far as ride quality and handling.
Check out this video in the link below. Only thing, If your truck is not lifted I think you would need the Bilstein 4600's
The FOX shocks are firm - which I prefer. I would guess that the Bilstein shocks are softer.
I checked my old receipts and I'm actually close to 60K / 4 years on the Fox's.
I also replaced the Ford stabilizer with the adjustable FOX one.
How do you know when you need new shocks? Or is it obvious? I'm getting up to 45k miles on mine, but I can't tell if it needs new shocks, but when camping, about 25k miles of that, are with a 5k pound truck camper in the bed. As far as I can tell, everything is fine. Had an alignment not to long ago, and didn't need hardly any adjustment.
Good video, but his explanation of how one is stiffer than the other is a bit off. These are not position sensitive shocks, they are speed sensitive. So you have to think of the damping in terms of shaft speed, not shaft position. Fox is valved softer on the low speed and stiffer on high shaft speeds compared to Bilstein. So Fox may have more body roll or diving under braking as those are slow shaft speed situations, but more resistance to bottoming and control over bigger, faster hits. On my F450 it is already wide with heavy spring rates so it's really planted on slow shock speed maneuvers anyway. I wanted more bottoming resistance when loaded hitting uneven bridges and frost heaves so I went with Fox. If I was running say a F250 lightly loaded daily driver I would have done Bilsteins for street handling.
Fox 2.0 monotubes take a special nitrogen needle fill setup. When I get to 50k miles on them I plan to rebuild and while I'm at it drill and tap my own shrader valve in the bottom end for easier rebuilding. Disclosure: I have a shock servicing setup in my garage and DO NOT recommend disassembling or modifying your own shocks without the proper tools and knowledge!
Is your 450 stock height? If so would you mind sharing part numbers for the fox shocks. I replaced the factory shocks at 30k with Bilstein 5100's which are ok for now. I am the worst demographic as I go from unloaded daily driving to towing our 18k rv to a 20-25k equipment load. I'm looking for something to calm the bottoming out when loaded exactly as you described. The long wheel base of the 450 amplifies those hits when towing in my opinion. Thanks in advance.
