Ford F-350 diesel 2001 engine, converted RV Ambulance.
TLDR: replaced AC compressor with a new unit twice. They broke down less than 300 miles each time replaced. I’m thinking it’s something more than the AC compressor unit. I’m looking for advice or knowledge of this situation
Long story:
I got this used converted ambulance. I had it looked at by two mechanics, they said it was fine. I took it out on its first long drive and with-in the first two hours AC goes out. I proceeded to drive 12 hours towards my destination and stopped at a Walmart parking lot to spend the night. Unfortunately, the truck would not start the next morning. I had a few professional diagnose the problem and they said it was the AC compressor that made it not start.
We replaced that part, and it started to work. However, after about 250 miles the AC goes out again and I was stuck with the same problem at a gas station. I, once again, got a mobile mechanic to come out and replace that part again. It worked after he did that.
After another 200 or so miles the AC once again goes off. I look at the engine and the belt is locking up. There is red dust around the part. I expect it to break down to the point where the truck would not start up again.
it seems like it’s more than the AC compressor. I’m looking for advice or any knowledge of my situation.
Are they flushing the system and at least installing a new orifice tube? Every ac compressor I've seen has a disclaimer saying no warranty if no proof of a flush, new orifice tube, and new accumulator/dryer. What is failing on these new compressors? To smoke a belt like that it has to be the pump not getting oiled or trash plugging it up, or the clutch bearing locking up. Did the new compressors have new clutches already installed?
These AC systems don’t have an orifice. Thermal Expansion Valve , TXV is used instead of an orifice tube. It’s essentially a variable orifice.
Mine has an orifice. That's what was in it when I went through the AC system, so that's what went back in. There were expansion valves listed on Rockauto right along with the regular orifices so I assume one could be put in it's place, but honestly don't know for sure.
What year truck? As far as I know all these 2024 trucks with failed compressors use a TXV instead of an orifice.
I was thinking the compressor got hot enough it smoked the clutch bearing, maybe it’s not possible but that’s where my mind went
Oh that. Yeah definitely need another pulley if the bearings are smoked. Sounds like the OP’s clutch locked solid and kept the belt from moving though.
