Missing 292
Old Jul 20, 2022 | 09:10 PM
TBirdDriver's Avatar
TBirdDriver
5th Gear
Missing 292
I own a 62 F100 with a 292 V8 that has a rebuilt 2 barrel carburetor. The carb has a manual choke. I very recently replaced the fuel pump because I thought it was failing. I also replaced the gasket between the spacer and the intake. The distributor has been converted to electronics. The gas tank is new. Gas is fresh and plugs and wires have been replaced. Up until recently starting was easy but recently when I try starting it runs with a bad miss until I try to start it 4-6 times. Then it runs and drives smoothly. If I shut it down sometimes I have to go through the whole sequence again before it starts.
Old Jul 20, 2022 | 09:25 PM
SwampRattFord's Avatar
SwampRattFord
How does it start warm with no choke?
Old Jul 20, 2022 | 09:38 PM
TBirdDriver
5th Gear
It behaves the same whether warm or cold.
Old Jul 21, 2022 | 03:39 PM
charliemccraney's Avatar
charliemccraney
Perform a compression check. Make sure fuel pressure is within spec. Check valve lash. When it is missing, check spark on all cylinders.
292v8hotrod
Aug 1, 2018 06:01 AM
cbowden1
Sep 4, 2016 08:41 PM
Spartacus1860
22
Jul 31, 2015 01:41 PM
prestondave
Jan 7, 2013 10:43 PM
reelickj
Jul 12, 2012 09:52 AM
