1978 - 1996 Big Bronco
Clunk or Thump on Acceleration
Old Nov 10, 2003 | 12:58 PM
carfreak113's Avatar
carfreak113
My '93, Auto, 5.8 has begun this thumping or clunking whenever I accelerate(both quickly and slowly) from dead stop and when I come to a complete stop it does the same thing just much less noticable. Almost feels like it is engaging and disengaging gears. Any suggestions or ideas!??!
Old Nov 10, 2003 | 01:24 PM
Crazyromi's Avatar
Crazyromi
This topic has been discussed many, many times. Use the search button up top and look up "clunk". You should get a lot of results. Most typical answer is that it is the slip-joint on your rear driveshaft. Pull the rubber boot back and regrease the joint and it should clear up your problem.
