Headlight issue?
Old Jul 19, 2022 | 08:53 AM
Garbageman 134's Avatar
Garbageman 134
Headlight issue?
22 F250 with factory halogen that I replaced with Auxito LED. When I start the truck during the day the headlights are not on but if I use the Flash to Pass feature the headlights come on High and stay on. I have to rotate the headlight switch to Off then back to Auto to turn them off.
Normal? Anyone else?
Old Jul 19, 2022 | 09:26 AM
BC2019F250's Avatar
BC2019F250
I would put the stock bulbs back in and see if it still happens.
Old Jul 20, 2022 | 07:21 AM
BDWSD22's Avatar
BDWSD22
Did your LED bulbs come with a power converter to go between the bulb and truck harness? If not, then that's likely causing trouble. If you don't have the converter harness, try setting the headlight type from halogen to LED using FORSCAN software and cycle the ignition before trying again. Good luck.
Old Jul 20, 2022 | 07:39 AM
Garbageman 134
They did. Truck power to adapter to led
Old Jul 21, 2022 | 05:16 AM
BDWSD22's Avatar
BDWSD22
If I were you, I would return the LED headlights back to where you bought them from and buy ones that actually do work without causing problems. My LED conversion worked A-OK. It's not an OEM LED conversion and it's not expensive.
I did the halogen to LED conversion a couple of weeks ago using an Headlight Experts kit. Their kit is lifetime warranted and per their advice, I included the $10 optional Warning cancellers / capacitors. The kit that I installed is on sale for $99.99 + $10 and I used the discount code 10PERCENT. Two of these kits are required for a '17-'22 Superduty with halogen headlights. Shipping was free and quick.
Installation was easy once I removed the headlight housings from the truck. The light produced is white, not amber like the OEM bulbs and makes it easier to see deer. Oncoming traffic does not bright light me thinking that I am using my high beams. The automatic high beans are not adversely affected and I received no headlamp warnings from the control module.
I'll be converting my fog lights to OEM LED units and reprogramming the control module using Forscan in the next few days. I converted my Nissan Altima and just received a set for my Suburban. Next I'll convert my Kawasaki. The only down side is that I can hear the little fans in the bulbs when the windows are down and the engine is not running.
Old Jul 21, 2022 | 05:47 AM
BDWSD22's Avatar
BDWSD22
Here's the Headlight Experts LED conversion in early morning. A nice bright white light.
ovenrat
2004 - 2008 F150
Feb 8, 2022 02:02 PM
ZachT93
42
Dec 5, 2021 10:49 PM
BroncoBoss351
1978 - 1996 Big Bronco
Sep 29, 2006 06:01 PM
horses4fun2
Dec 31, 2004 08:06 AM
