1989 ford e350 5.8 extended. schoolbus seats 15, battling ac. My ac mechanic sent me the attached photos saying that hte tube that connects front to rear a/c is damaged and needs to be replaced soon. (I currently am replacing damn near everything else to battle miami heat. However he cannot find the part number or what it is called in ENglish. Can anybody from the group help
Even if you found a part number that high side hose will have long been obsolete
You should be able to find one from an AC supplier
Like 1 800 Radiator
Its the high side hose
Usually you would say where it comes from and where it goes
Cannot tell that from the photos, but a van with rear air means, that hose might be called
High side hose compressor to tube or manifold to tube
Last BMW I was fighting I just had Evco house of hose make me one up
That is an option, not an easy one though due to the length and complexity of that hose
Good luck
More pics would help maybe
