A/C troubleshooting
Old Jul 16, 2022 | 06:08 PM
rod.d's Avatar
rod.d
A/C troubleshooting
I’m trying to get the ac working on my new to me 1988 f250. The previous owner converted it to r134a, so that’s good. The problem is the compressor doesn’t come on. I thought it might be low on refrigerant, but it’s not, which is also good. I tried to out a volt meter on the compressor plug, but it shows like .02 volts, which is weird, but when the ac is off it’s actually higher, around .2v. Does anyone know of a troubleshooting guide? The light on the ac button comes on, and I’m sure there’s a bunch of pressure switches and relays somewhere, I just don’t know where to start. Thanks
Old Jul 16, 2022 | 06:09 PM
SFaulken's Avatar
SFaulken
There is exactly 1 pressure switch. It is screwed into the side of the filter dryer.
Old Jul 16, 2022 | 06:37 PM
rod.d's Avatar
rod.d
so can I just jumper around that? I couldn’t find any fuses anywhere, I’m not sure what else to try.
Old Jul 16, 2022 | 06:52 PM
SFaulken's Avatar
SFaulken
If you jumper around the switch, and the compressor turns on, either the switch is bad, or you've got a pressure issue in your A/C System.
Old Jul 17, 2022 | 01:50 PM
rod.d's Avatar
rod.d
cool, thanks for the help! I jumped around the pressure switch and the compressor came on. Then the pressure was lower, so I wasn't reading the correct static pressure before. Turns out it was low, after charging it blows colder, but not what I would consider cold. I am going to run it for a while and see if it leaks out. The truck has been sitting for a while, and I'm hoping the sealant additive in the refrigerant will take care of it, but that's probably optimistic. Anyway, happy that the system itself works, I can deal with replacing o-rings later if necessary.
NapaValley
Nov 28, 2018 10:34 AM
oldbird1965
41
Nov 7, 2018 12:32 PM
JWI1965
May 21, 2017 10:54 PM
octaneforce
Jun 5, 2012 01:30 AM
bcalhoon
May 9, 2011 04:35 PM
