Sponsored by: Real Truck
Turbo problem
Old Jul 15, 2022 | 11:08 PM
DuncanB's Avatar
DuncanB
Trailering
Turbo problem
Bought a 2003 turbo for my 2005 f250 6.0 powerstroke, rebuilt the turbo with a kc rebuild kit, used Lucas oil assembly lube for the shaft and bearins and it was pretty thick and very sticky, when i installed the turbo I only was getting about 10 psi, would this be from the thick oil and it not letting the turbine spin As fast as it needs to? Also I had oil being shot everywhere in my engine bay would this be from the oil drain not being seated properly into the turbo? I am mostly just concerned about the turbo boost not being what it used to be
Old Jul 16, 2022 | 05:43 PM
Evan_P's Avatar
Evan_P
You need to find the source of that leak. Dont ignore it. As for the lack of boost I assume you cleaned the exhaust housing and made sure the unison ring moved freely as it should? If so take a look at this:
Old Jul 16, 2022 | 06:43 PM
DuncanB's Avatar
DuncanB
Trailering
https://www.youtube.com/watch?v=vhBf...=DieselTechRon
I did a full rebuild on the turbo, fixed the oil leak on the turbo, found out the guy I bought the turbo from had the silencer ring removed, I'm wondering if that is why I don't get as much boost as I used to
Hihihidude13
Jan 25, 2020 01:53 PM
mcali2
Jan 10, 2018 08:52 AM
donmi
Sep 21, 2012 12:42 AM
noshow
Dec 6, 2010 03:37 PM
Tarzan
Feb 26, 2004 08:52 AM
