Truck Purchasing Advice
I am looking to buy my first truck, and I want it to be something relatively easy to work on. While I'm pretty confident in unbolt/rebolt repairs, my automotive knowledge past changing fluids and filters is virtually nonexistent, and I want a truck that will be somewhat easy to learn to work on. I believe I have narrowed it down to an 85' or before that sports a 300 i6 with a carb, but what years do y'all think are the best to go with / which years to stay away from? If I find a good deal on a mid to late 70s truck, is it worth it to hold out for an early to mid 80s truck? Also, when looking at a truck to purchase, what should I be on the lookout for that would make me instantly walk away from the deal?
Thanks y'all,
Duane424
Things to lookout for do you mean in general? or bullnose specific? or yes?
Here's a checklist I usually go thru and things I consider red flags:
Red Flags:
- Ran when parked/should run with a little TLC/just needs a carb adjustment
- When a carbed motor doesn't work EVERYONE says the above. Could it be something simple? sure. Could it be that the motor is corked? yes. Am I lucky with which of those it will be? never
- Engine not running and checking under the hood it is a wild partially messed with jumble
- This means not only do you need to figure out what the original issue was but now you have to figure out what the PO did and how to fix that too
- Owner won't try to run the motor
- Tells me he thinks it won't work but wants to sell it to me like it will.
- Sparkly/glittery motor oil
- You have an engine rebuild in the future
- Brand new oil
- Could be thoughtful or could be to hide the situation
- How rusty is the frame/undercarriage
- How much body work does it need (I dislike body work so I try to avoid it if I can)
- Does it have the stuff I want? Sure I can mod it but it's just easier (and usually cheaper) if it already has it
- What am I going to have to replace to get it roadworthy: tires, brakes, etc
- Clean title
- Bullnose (or really ford truck) Specific:
- How rusted is the bed?
- How are the cab corners?
- Cab mounts?
- How rusted is the cab roof (this is more pre-bullnose as far as I've noticed)
- If manual with manual linkage how much play is in the linkage?
- if manual with hydraulic clutch does the cab firewall flex?
I'd say as a rule when it comes to walking away most of the generic car buying advice holds. I also tend to trust my gut. I'm a pretty easy going guy and if I get a bad feeling from the seller I'll usually pass on the buy.
If you do end up going in to the mid 70s just know that every 360FE is a 390FE on the day of the sale.
Hope my ramble helped some. feel free to ping for more info. If you are shopping on Craigslist or the like you can likely post the link up here and you'd get more engagement with advice based on what the pictures show and the price point.
The AOD gives you a four speed auto with an overdrive, but is not durable without modifications - compared to the 3-speed automatics C4 (medium duty} & C6 (heavy duty).
The NP435 & T18 manual transmissions are heavy duty 4-speeds with a creeper 1st gear; while the 4-speed OD manual transmissions give you better fuel economy, but not the same durability.
If you stick with the 1980-up trucks, you will find generally they have more standard features and options. Its very rare to not have power steering, while not having power steering is more common in the 70's trucks. A/C is more common, even power brakes are more common. Hurry up though, these trucks are becoming more popular and thus more expensive.
Hauling?
Towing?
Daily driver?
Highway?
Off road?
When you know these things it's easier to determine which trucks are best suited for you.
Also consider the 6.9l diesel engines. These engines typically last for 300 to 400k miles. Require very little work for 100 to 150 thousand miles between tune ups which are more expensive than gasser tune ups for sure. With the E85 fuel for gas trucks you run into many issues. With diesel you don't have any fuel issues. If the truck is going to be used infrequently you don't have to worry about fuel going bad or damaging your carb and other components or attracting moisture to the fuel system.
If I were looking at Bullnoses I'd definitely consider the diesel.
I've been married to one for 36 happy years.
