Modular V10 (6.8l)
V10 reads hot while pulling trailer
Old Jul 14, 2022 | 08:36 PM
blackdakotadave's Avatar
blackdakotadave
Trailering
Lightbulb V10 reads hot while pulling trailer
My 2001 F250 with 6.8 reads hot while pulling trailers. The oil and coolant are fine. Could this be a plugged catalytic converter? Need Help...Thanks
Old Jul 14, 2022 | 08:42 PM
blackdakotadave
Trailering
hot v10
Something other than the temperature sender is triggering a hot scenario which puts the engine into "limp mode". Shutting down and restarting resets the hot scenario.
Old Jul 15, 2022 | 04:59 PM
Dweber85rc's Avatar
Dweber85rc
What do you mean exactly by "reads hot"? Do you have an actual temperature gauge with numbers or just going by the gauge in the dash?
Old Jul 16, 2022 | 06:05 AM
JWA's Avatar
JWA
Alternately using an IR thermometer pointed at the thermostat housing with engine running ASAP when the limp mode is triggered would work. So would having a scanner connected to the OBD-ll port with a "view data" function when trailering to monitor the coolant temperature would work as well.
Old Jul 16, 2022 | 08:03 AM
blackdakotadave
Trailering
I am guessing that the temperature sensor is not accurate. It is telling me that the temp is good, until that moment that it triggers the limp mode. Also, I am pretty sure that the fan clutch is weak, and cools enough when not towing, but not enough when towing on a hill. I have ordered a new temp sensor from Ford, as well as a fan clutch. We'll see if that solves the problem.
Faves61
All Things Towing
May 5, 2018 05:27 PM
360F100
Modular V10 (6.8l)
15
Nov 23, 2011 10:05 AM
mt-man
Jun 12, 2011 01:39 PM
Fishin Technician
Sep 2, 2002 07:50 PM
mwrichm
Oct 16, 2001 06:31 AM
