Sponsored by: Real Truck
Instrument cluster not work
Old Jul 13, 2022 | 01:44 PM
Datk's Avatar
Datk
1st Gear
I sent my cluster in to get repaired, it still doesn't work the windows and radio work fine, iv check all the fuses and they all check good, nothing on the cluster works and the overdrive don't work I also replaced my shifter. Does anyone know what it could be ? It's a 2003 f250 with the v10
Old Jul 13, 2022 | 07:00 PM
pbsdaddy's Avatar
pbsdaddy
Welcome to FTE. Please take your questions to the forums the align with. For example. You could ask your question in the, "miscellaneous, (electrical), section, or the, "Super Duty/Heavy Duty" section. You will morel likely getthe help you seek, in those sections. Not people come to the intro section, to answer questions.
Don't forget to join your state chapter too. Some times, the best help, is right close by.
Old Jul 13, 2022 | 11:10 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Welcome aboard!
Old Jul 14, 2022 | 09:35 PM
donjamer's Avatar
donjamer
Moved to Appropriate forum
Old Jul 15, 2022 | 12:11 AM
2001F350dualwheel's Avatar
2001F350dualwheel
Check the grounds. I can look and see I may have the cluster out of the 2002 v10 I parted out a while back. And i know it works But if nothing works even the CEL when you turn on he key you may not have ground at the cluster. Or some connector isn’t connected all the way. You should at least have guage lights come on. Look at the pin outs and grab a meter. Test for power and ground at the connector
Tony_TAT2
Apr 5, 2017 05:11 PM
mustang68s
Testing.....
Oct 17, 2009 07:38 PM
mjwhip2
Jun 6, 2005 03:20 AM
rc351w
Feb 1, 2002 02:03 PM
