Taillight problem
Old Jul 8, 2022 | 10:36 PM
chuck3908's Avatar
chuck3908
Trailering
Taillight problem
Hello all, 68 f100 all turn signals work, all brakes lights work but the left rear taillight doesn’t work. I cleaned to the connectors to the housing, changed bulb, tried another housing but when that went on the turn signal on that same side now didn’t work so I put the original housing back in. Any suggestions? Thanks
Old Jul 9, 2022 | 10:26 AM
RTT's Avatar
RTT
Check all the wires for cracks or loose connections........look for grounds............if one taillight works the other should so must be a bad connection somewhere........
Old Jul 10, 2022 | 05:39 PM
Mattress's Avatar
Mattress
4wd Low
If you're referring to the backup/reverse light, I just had the same problem on my 68 F100 and it was just a bad ground connection from all the oxidation around the screws and rivets of the housing. I'd try cleaning those screws and ensure a good ground connection, specifically on the lower screw. Good luck.
RickT64
Aug 6, 2021 08:58 PM
CB3
Aug 6, 2015 10:07 PM
lazyd
Aug 27, 2011 07:15 PM
pistolpty
Nov 17, 2007 08:48 PM
cjben
31
Jul 22, 2005 08:47 PM
