tail-lights out
Old Nov 10, 2003 | 08:20 AM
sju150's Avatar
sju150
tail-lights out
Hi,
While driving home at night recently I got pulled over and was told by the officer that my tail-lights weren't working. He was right, of course. Brake lights and turn signals function properly, just missing the lights in question.
Pulled fuse number 5 of the passenger compartment fuse panel -- looked fine. Also, looked at fuse 9 in the power distribution box and that appeared normal.
Either I checked the wrong fuses or the problem lies elsewhere...
The officer didn't give me a ticket, but I did have to drive home with my hazards on for 15 miles.
If anyone can point me in the right direction, I'd appreciate it.
Thanks,
sju150, 2001 F-150 Supercrew owner
Old Nov 10, 2003 | 01:17 PM
Franklin2's Avatar
Franklin2
Is your license plate light in the rear working?
Old Nov 10, 2003 | 01:27 PM
sju150's Avatar
sju150
Good call -- they also appear to be affected.
Old Nov 10, 2003 | 01:53 PM
macguyver's Avatar
macguyver
Check to see if anyone has installed a trailer connector. The (brown) wire could be corroded there or possibly at the connector at the left rear of the frame.
Old Nov 11, 2003 | 03:21 PM
sju150's Avatar
sju150
fixed
Thanks for the remarks and suggestions. I looked at the wiring and the wiring leading to the trailer connector. I didn't see anything wrong there or the wiring in the left rear of the truck.
I brought it into my local Ford dealer and let them have a go at it. They eventually found the problem after about 2 hours. A bolt from the bed apparently rubbed all the way through the plastic shielding and severed the (brown) wire. The location of the busted wire was about 2 to 3 feet from the rear of the truck (going up left side).
Pretty unusual if you ask me.
Thanks again.
