another Y block question...? Carl?
I currently have 2 y block engines, a 59 in my truck and a parts engine. the parts engine had a spin on adapter which I removed about six months ago. ?? is do I use the old cartridge filter assembly for the gasket behind the plate, and does the slit in the plate go on top??
DO NOT, repeat after me, DO NOT use a Fram filter.
I lost 15 lbs pressure and thought I was losing the engine before I heard others Fram horror stories.
Went back to Motorcraft and Hastings real fas.
BTW, Im often not around the PC on weekends.
