Abs sensor help
Old Jul 13, 2022 | 03:50 PM
FordTruckNoob's Avatar
FordTruckNoob
Do you have metallic particles in the grease covering the tone rings?
Old Jul 13, 2022 | 04:55 PM
Fball1208's Avatar
Fball1208
No they had some dirt in them but nothing else, They were clean otherwise. and are clean now.
Old Jul 13, 2022 | 05:09 PM
FordTruckNoob
Unless you have reason to suspect the wiring going from the ABS sensors to the ABS Module then you are probably right that the ABS Module is kaput. I have actually disabled my ABS because it is more hindrance than help for me but then I don’t have funny speedo readings.
Old Jul 13, 2022 | 05:12 PM
Fball1208's Avatar
Fball1208
The speedo issue is what im worried about as its causing the shifting issues, ABS i can live with out.
Old Jul 13, 2022 | 05:13 PM
FordTruckNoob
Just for S&Gs, unplug the ABS fuse to see if that does anything.
Old Jul 13, 2022 | 05:47 PM
Fball1208's Avatar
Fball1208
Pulled the fuse, No Speedo but the truck runs and shifts right now. So.....
Old Jul 13, 2022 | 05:55 PM
FordTruckNoob
Hmmm. My speedo still works even after the ABS fuse got pulled but then mine is a 2000. Shifting was okay after fuse got pulled?
Old Jul 13, 2022 | 06:00 PM
Fball1208's Avatar
Fball1208
Yeah shifting and everything worked after fuse was pulled just no speedo, it stays at 0 atleast now and not 50 and bouncing
Old Jul 13, 2022 | 06:16 PM
FordTruckNoob
Okay. That’s progress of sorts.
Old Jul 13, 2022 | 06:18 PM
Fball1208's Avatar
Fball1208
Defiantly, This makes me wonder if its not the abs module thats the issue, Since now its not getting power the issue has gone.
Old Jul 15, 2022 | 09:48 AM
udsuth78's Avatar
udsuth78
I found this post in another thread and thought it useful information to have. I believe the GEM's were replaced with a BCM or something like that in 02 maybe, but I would suspect the routing of the signal is going through it rather than straight to the cluster.
Originally Posted by Uzumati
The VSS signal is an ABS signal that is fed to the GEM to be sent to the Cluster gauge. With a failed VSS the ABS will still provide a signal to the GEM from the front wheel sensors. There are several circuits that could be shorted causing the loss of speedo and not the gauge itsself. PM me your email if you want the pinpoints to check it out.
Old Jul 23, 2022 | 10:19 PM
Fball1208's Avatar
Fball1208
Thanks i have a module on the way going to change it see if anything changes if not its going to a local auto electric place to get looked at.
Old Aug 9, 2022 | 07:31 PM
  #28
Fball1208's Avatar
Fball1208
Well its been awhile but finally got the module changed out which was not fun, Everything works as it should now. Thanks for the help and suggestions
Old Aug 9, 2022 | 09:01 PM
  #29
udsuth78's Avatar
udsuth78
Sweet, good to hear she's on the straight and narrow.
Old Aug 9, 2022 | 09:08 PM
  #30
2001F350dualwheel's Avatar
2001F350dualwheel
Originally Posted by Fball1208
Well since y’all were so helpful on my last post maybe someone knows what I can do now. 03 f350 rwd rear abs sensor was bad. Changed it. Worked until I pulled out and now showing code for it again. When this happens my speedometer quits working. Remove sensor and put back in works again. Hit a bump quit working. What should I be looking at. Thanks
bad connector. Look for crushed or pinched wiring along the loom.
