2017 coolant questions
Old Jun 29, 2022 | 11:33 AM
johndeerefarmer's Avatar
johndeerefarmer
I am draining the coolant on my 2017 3.5 eco. I have the cap off and drain open. I have only got about a quart out of it. Any tricks to drain it? Remove radiator hose?
Also I bought Prestone Universal. It's suppose to be ok to mix with any OEM fluid?
Old Jun 29, 2022 | 01:09 PM
scott91370's Avatar
scott91370
If it isn't draining you may need to pull the top hose.
I would use the new Motorcraft Yellow coolant if I were changing mine.
Old Jun 29, 2022 | 04:01 PM
Stealth13777's Avatar
Stealth13777
+1 on Ford coolant. You also won’t get it all out, and that’s ok.
If you bought coolant that is not pre-mixed, make sure you are mixing with distilled water.
Old Jun 30, 2022 | 11:07 AM
johndeerefarmer
Only got out about 1.5 gallons. Added back 1.5 gallons of DEXCOOL premix from ZEREX. I think I will drive it awhile then drain another gallon then add another gallon of new. At least I will have more of the new mix in it.
fordman19762003
Jun 24, 2017 06:13 AM
choate
Sep 30, 2014 11:15 PM
Lushman
33
Aug 16, 2006 07:52 AM
fishmanndotcom
13
Mar 27, 2006 05:47 AM
PSDLOVER
Sep 28, 2003 09:59 PM
