292 hd 4 barrel?
Old Jun 28, 2022 | 09:12 PM
ford highboy!'s Avatar
ford highboy!
292 hd 4 barrel?
is the 4 barrel intake off of a heavy duty 292 good to use for a mildly modded 292 y block? going in a 60 f350
Old Jun 28, 2022 | 09:51 PM
85e150's Avatar
85e150
Check if for carb fit and see if it has a governor under the carb.
Old Jun 28, 2022 | 09:55 PM
ford highboy!
what will the governor look like? the engine is currently in a c600 cabover with a wrecker body on it and i cant get the cab up right now
Old Jun 29, 2022 | 06:36 AM
ojh's Avatar
ojh
I wouldn't think the F350 would need a governor, more applicable is I think it would've been whats called the 'teapot' 4bbl, not a very successful carburetor, very short lived. I'd replace it with a Carter unless you go with an adapter and use a 'modern' Edelbrock.
Old Jun 29, 2022 | 07:16 AM
ford highboy!
I think im going to go with this 450 cfm quick fuel carb https://www.holley.com/products/fuel...arts/SL-450-VS . the engine currently has an adapter to go from a 4 barrel to a 2 barrel with what looks like a holley 2100 on it
Old Jun 29, 2022 | 03:39 PM
charliemccraney's Avatar
charliemccraney
The factory intake that you want is ECZ 9425-B. I think that is what an HD engine would have.
Old Jun 29, 2022 | 04:00 PM
ford highboy!
the engine is a 1962 so it should have the better manifold
ford highboy!
it also has a set of oem rams horn exhaust manifolds
F250racer
May 8, 2010 10:49 AM
64 hi-boy
May 3, 2010 11:43 AM
al37ford
Oct 19, 2006 05:48 AM
286merc
Aug 17, 2001 12:44 AM
