Anybody add an aux fan to their condenser?
Your profile shows a 97, that truck would benefit from a pusher fan on the condenser, that year system will run till the high side reaches ~450psi then open the clutch till the pressure drops down to ~260psi then allow the clutch to turn on again.
Btw I never had my clutch fan kick in and it’s 107 at my house today. Assuming your coolant levels are topped off and you changed the coolant at some point of ownership?
another thing to do is to shut off the coolant lines going to the heater core. Get a electronically controlled heater core block off. That’s gonna keep the hot coolant out of the heater core. If yiu have a gas car get a vacuum operated one
https://www.amazon.com/Electronic-Bypass-Heater-Valve-50-1555/dp/B00LEUV98M
wire it up through a relay. Probably 30 amp. How do you want it to come on? Temp controlled, manual or key on comes on?
another good air mover is one off a Hyundai Santa Fe or Kia Sorento. Those things have huge fans also
What you mean like hook up the fan straight to the compressor? No you don’t wanna do that.
Just wire it up as a key on accessory. I wood use a relay to send power through to the fan itself. Dont use the on switch as the connection to the fan main power feed.
you need to find the wire that switches the compressor on at the compressor. It’s either gonna be a positive or negative switch leg so you’ll need to wire the relay the same way. Got a volt meter?
let me know how your truck is set up and I can tell you how to wire up the relay.
So I'm thinking of this fan
90W so 7.5A
for the relay
Connectors ( i believe these are the correct ones)
MOTORCRAFT WPT173 {1U2J14B475AJA, 1U2Z14S411AJA, 1U2Z*14S411*AJA} Info
MOTORCRAFT WPT984 {3U2Z14S411BXAB, 3U2Z*14S411*BXAB} Backlit Scuff Plate (Lamps) Connector Info
I think for this application I can use 10 G wire with a 10A inline fuse.
When you say "let me know how your truck is set up", what do you mean? It's an 08 F350 6.4 D
90W so 7.5A
for the relay
On the AC high pressure switch, there is a green/blue wire that gets grounded when the discharge pressure goes above ~250psi, you could hook your relay coil ground to that wire so when the pressure goes high enough it will automatically turn on your fan.
You can’t use a 10A fuse for that fan, it needs to be 3-4 times large so it doesn’t blow when the fan try’s to start up. The link you posted shows a 30-40a fuse for the feed power to the fan.
